Hi all,
On the way home tonight my rear brake did the following:
- the pedal whent solid - and I could feel the drag from the rear brake.
- the pedal then went completely loose - all the way to the floor.
- after not using it for a while - it seemed to regain a little bit of braking ability - but nowhere near its normal function - it also felt like here was a little drag still - but need to check that later.
This was after quite a bit filtering.
I haven’t yet been able to investigate - by wanted to gather options on what to look for that might have caused this.
