Race winning 71bhp MiniTwin Track/Racebike SV650
Also on Ebay (220694832185), spec is:
Mark Hill’s MHP Minitwin. Mark’s had 4 trophies on it this year. 1 @ Snetterton, 3 @ Pembrey.
  • V5 log book
  • Ohlins rear suspension unit, will suit 12-15 stone
  • R6 99 internal cartridge modified to fit in forks with 9.5 springs in both legs. This allows 10w oil to be used which is less prone to temperature changes than the 20w oil that is used by emulators or welded damper rods.
  • 71 hp
  • bridgestone wets on wheels, used, rear has captive spacers as does the dry wheel (less bits to worry about when youre changing your wheels over)
  • 1098 fairing and seat, mhp bespoke lightweight seat subframe
  • Quick release tank filler cap
  • SDC battery converstion to r/h/s (next to front cylinder)
  • 7amp/hour battery lighter than stock
  • 520 DID ZVM chain
  • 14T and 15T front sprockets
  • 44 and 45 rear sprockets
  • Cadmatic custom rearsets (brand new intended to allow maximum clearance and adjustability)
  • factory pro detent spring for gear change efficiency
  • Venhill quick action throttle
  • beautiful rainbow-coloured full MHP exhaust system: titanium link pipe, oval titanium silencer around 100db (legal pretty much everywhere except Mallory without the baffle).
  • SBS racing dual carbon brake pads
  • Braided front and brake lines
  • only one small negative: fairing still has a light gravel scuffing on left, hence reduction in price
£3,600, based Stevenage/Colchester
Gabs 0787 96 121 60
Hi Hun ,
Does this mean that Mark has hung up his leathers ???.. i hope not :O(
Dinner soon ???
XXX
SPG
