PLEASE HELP
I WANA STREET FIGHTER ME GIXER K4 600
!!!I NEED HELP!!!
any suggestions as to wat riesers and how to wire up and enduro type headlight would be apprieciated
It would probably look better with a new set of yokes with risers and some renthal fat bars. Hooking up the lights should be easy enough, but most enduro lights done have a dip beam. So they are either on or off.
You’ve seen the lite Kev :slight_smile:
If you do go down the riser route, I’d have em welded to the yokes.
Most of the little fighter type fairing’s run kitchen spot light bulbs and are sh*t, as El says there either on or off.
If you need a hand with the wiring, giss a shout :wink:
So what else is on your shopping list ?
personally I’d change your radial caliper forks and fit a set of Gsxr wt one’s on, as it goe’s I got a set that I’ll swap ya :smiley:
I’ve got a k4 gsxr light I’m carving up for my Bandit project. If you still have yours play about with it. There is nothing a sheet of abs plastic, some fibreglass and body filler cant do.
nooooooooooooo dont let terry near the wiring:w00t: (only joking gimpmaster)look at steves k on my siteterrys got the cheap option on the bars or tes engineering will do you a ypke conversion not cheap but quality;)
TES are not that reliable…if you’re needing some yokes made up let me know I know a man that can…and you could always just drop it round SPARTS place as he knows a thing or two about building a tasty fighter
terry thanx but no thanx… numbty
spart wats ur website
i migh av alook
a quick search and i found it
WOW!!! that looks the bo!!ocks thats basically wat i wanted to do to mine, paint an all but now i have to think about a new paint schem BUGGER!!!
i found a kitt which uses new yokes with risers built in also has lenghened braided brake lines aswell for about £300 which is not bad i supose i`m gona get them wen i get me new bottom yokes.
www.spartgsxrspecials.com/ :wink:
thanx tel that k3 looks the bo!!ocks i will be diving in once i`ve sorted the funds out WATCH DIS SPACE
Thats Dans from Carbontek. If you’ve got any queries give them a shout.
Whoops, no its not, very simular tho’.
That be mine, fuggin fantastic ride…flat bars are the way to hell
