Paddock stand bobbins for CBR600F
Sorry to bug again, but someone kindly mentioned that I could get away without my centrestand and without destroying my scottoiler if I fit paddock stand bobbins to the bike.
I’ve now picked the bike up, but I can’t work out where to get bobbins from. I can’t see anywhere that they would be mounted, which is also confusing me - on the Kwak, there were two holes that were specifically designed and placed for this, but on the CBR, I can’t see anything.
I’ve found these: http://www.rg-racing.com/browseBike/Honda/CBR600(Alu_Frame)/2006/PB00M8.aspx on the R&G site, but they’re very vague on whether or not they are suitable - any ideas ?
Thanks again :slight_smile:
IIRC the CBR 6 F has a hollow axle like the Firestorm.
You can get bobbins that fit the axle like these
The above of course works … unless you’re removing the wheel. I looked into this a year ago and it seems the only other option is to weld on some nuts to screw the bobbins into.
That is very true and a good point:Whistling:
This - http://www.cbr-forum.org.uk/index.php - is a good place to look for answers to any CBR specific questions.
Stupid question - but what do you mean they work unless you’re removing the wheel ? Does this cause a problem when you come to change tyres or something ?
Phone up M&P http://www.mandp.co.uk/or Demon tweeks http://www.demon-tweeks.co.uk/
tell em what bike you’ve got and they should be able to tell you what size bobbins you need - the bobbins size you need will fall intothe following thread range: 6/8/10 or 12mmm.
Just spoke to both of them and they both told me the same thing - they can’t help me if bobbin fitting points aren’t present on the bike.
Looks like we’re back to having to get the centre stand refitted and the exhaust modded to work with that. Bummer.
Can’t you just use an abba stand :slight_smile:
Starting to look like I’ll have to buy one of those. Just more cost I could have lived without really :frowning:
Still tempted to get rid of the Akrapovic exhaust and get the original fitted back on. I’m sure that’s within my limited technical ability - then I can use the centre stand again.
Sorry - I didn’r realise it hasn’t got the drilling points - if that’s the case then an Abba stand is your best bet.
Looking back at the original problem, would it not be easier and cheaper to re-route the Scotoiler tube?
The axle bobbins i posted work perfectly for chai adjustment, cleaning etc, but can’t be used for wheel removal as you need to remove the spindle:w00t:
Depends if you will be changing your own wheels or using ride-in, ride-out tyre firms:)
Abba would be the best solution but you wanted to do it on a budget:)
I’d still prefer to do it on a budget :smiley: I only ever use ride-in / ride-out type firms, mainly honda and Essential Rubber. But I couldn’t find any of those axle bobbins for the CBR600F online today. I spoke to R&G on the phone and they do them for other bikes, but not mine.
If there are any other manufacturers who do them, I’d still like to give them a try. Otherwise I’ll get the Abba in April at the earliest.
What you could do instead of the bobbins i suggested is to get a length of steel rod or studding which would fit through your rear axle (poss 1/2" or 5/8") and use that with the “V” paddock stand ends.
That would only cost a couple of quid:cool:
Nice bit of creative/lateral thinking Chunky! :cool:
Failing all this, you can always revert to the old tried and tested “stick” technique:cool:
Hmm - that’s actually not bad. Just get a threaded length so that I can weld a bolt onto one side and spin one onto the other end, just so that it doesn’t slide. Cunning !
You peeps are geniuses :slight_smile:
Maybe a stupid comment, but when I was at Essential with my cbr FS the other week they used a set of stands with flat pads which fitted on the swing arm? Are these not any good - was two man job but more for security I think.
The problem is that they would crush the pipe on his scotoiler:)
Ahhh - so much to bloody think about!! Already getting pissed off with just a side stand when doing simple routine jobs so also looking at same prob. No 'oiler for me so would the pad type may be the way for me.
I’d keep the exhaust and go for one of the solutions posted by these guys!
