this happened twice to me today, first time this morning on my commute to work. I always let the machine run first for a few minutes before I go off.
After about a mile down the road I saw the light on, stopped on a side road quickly, and after a few seconds w/o doing anything, the light went off again.
This evening on my way home from work it was the same thing, the light went off, I stopped at a roadworks on London Wall (couldn’t stop anywhere else before), and after a few seconds by then it went off again.
Both times afterwards it did not light up again.
Bit funny too, since exactly yesterday evening I checked the oil level and it seemed fine, SeebyRJohno double checked mine too just to be safe, and agreed as well that it’s still way within limits, it’s exactly between the top and bottom marker on the oil checker.
What could a possible reason be for this occurrence?
I’d look at if there are any blockages preventing the oil from circulating properly first (i.e. change the oil, maybe engine cleaner) as it’s less expensive!
When I bought the bike, 4k miles ago…
I actually need to do a service, got most stuff here already, incl. new oil filter, will throw in Castrol 10W40 probably.
Engine cleaner, that the stuff you throw into the petrol?
I have some wurth engine cleaner, you stick it in the oil. I can’t say it is worth it as I haven’t used it but I’ve seen some good reviews, especially for older engines.
I’d get some decent semi-synth (at least) oil and do a change and see what happens!
Also if there’s a fazer forum check there, it might be a known issue
EDIT: there’s no way it’s a fault code bitching at you about being due a service is there?!
Right, poked around on FOC-U a bit, it looks like a bit of a dirt/gunk build up, and others have noticed this usually too around the time when an oil change was needed, so yeah, it’s about time for oil change…
Just ordered the Würth Engine flush and cleaner too, should be here by Friday latest, so it can go in right with the new oil
The two most common causes for low oil pressure warning light are:
Low oil level
Blocked or clogged oil filter
Given the symptoms ‘intermittent oil warning light’ and since the oil level is reported to be OK, I’d suspect the filter.
Remedy …
Oil and filter replacement with an engine flush.
I’d recommend you drain engine oil, fill to level with flushing oil, run engine per instructions on flushing oil container, drain flushing oil, replace oil filter, re-fill with fresh engine oil. I’d not put any additional additives in the oil just go for a decent specification oil that will already have all the additives in it that you need.
