Does anyone know if the number plate light is a legal requirement to pass an MOT?
Reason i ask is because im going to fit an under tray to my bike and it’ll be less hassle to do away with the number plate light rather than work a way of incorporating it into the under tray. (it’ll probably look a lot better too)
I was wondering/hoping if the light from the tail light which is permanently on would be sufficient for an mot pass
You can use the light from a tail light but it must be clear where it shines on the plate . Cut out a rectangle and glue in a clear bit of plastic and you will pass … I did
iv used those bolt ones had to buy a new set each mot as the first set i ripped the wires out and the second set broke arfter 3 days but good for the mot non the less
