I have noticed over the last couple of nights my bikes tends to start shaking its head when I get the power on - and I mean on - out of turns or even slight bends - a2 for eg. The shaking head is actually more like a definite slow no like your mum or dad would do when looking at you whilst considering dropping a water bomb out of a window for eg.
I have had a new front tyre fitted recently but I am sure this head shaking didn’t develop overnight. I have had some decent spurts up and around the a2 with the new tyre fitted with hardly any weaving on the front.
Its an SV thou, budget but competent steering damper fitted.
What can I do to experiment eliminating this? I have tried goading it tonight. Slight weave, more power, more weave, more power, even more weave. I slowed down before the weave developed.
Bear in mind I am no mechanic or practical really!
After checking tyre pressures (as Charlie says). Make sure your grip on the bars is not tight as this will make things worse. If you like grip the tank with your knees if the bars flap.
Id check the suspension as well. If the front end is sitting too high and the rear squats too much under accelereation then the front naturally goes too light, making it flap more easily. Try leaning more towards the front of the bike when accelerating. Its hard to say exactly whats wrong without someone actually looking at it, but to start with id be tempted to dial in some more rebound damping (if you have that adjustment) on the front end to stop it unloading too quickly.
There again you might have too much preload on the front and not enough preload or compression damping on the rear.
I would go with getting the wheel re balanced. Had the same thing last week. I had heavy vibrations around 80-90mph . Soon stopped when the wheel was re balanced. Now gotta look at my brake discs as i think there broken!
