I was wondering if anyoe could help me with my question.as stated above i have a 250 ninja which is my first bike since passing my test.
As it is a sports bike it revs quite high which is new to me and i keep looking for another gear,is it possible to put a gear indicator on this bike to visually display which gear I am in.I know im opening myself up for some abuse about counting and stuff but feel it would make my life a lot easier.
It won’t make your life easier… You will just become lazy…
I also inquired about fitting one on my first bike and once I ordered it and thought about it the idea soon wore off!
Eventually you’ll get used to riding and riding your bike, counting the gears will be an instinct with in no time… Just get used to listening to the rpm it’ll make you a better rider in the long run…
I’m sure a few others can shed some more light on it, but IMO its not worth the faff…
I’ve got one for the 600RR. It’s the coolest thing ever and looks really trick. I rode for 2 years on the CB500 without one and that was fine. I find it useful on the RR for when you are entering a slow corner and want to be sure how many clicks it is to 1st. Also if you want a burst of acceleration on the motorway or an A road it’s convenient to know what gear you are in so you know how many you want to drop. For example if you are doing 70 and you want to pass or get away from something you know that you can still drop to 2nd but 1st is a bad idea. So if you look down and see you are in 5th you can confidently hammer down 3 ratios and open it up. I’ve found it pretty useful since it’s been there.
I find i only need a gear indicator to know which gear i am about to wheelie in (to get the revs right)…:ermm::Whistling: although i always try for 7th hoping one has magically appeared and i can go supersonic!!
it is useful but you will get used to knowing/counting the gears soon enough and find you won’t even check after a while if you have one installed!
