My heated grips controller mod
So the controller unit for my Oxford heated grips had been playing up for a while… They would occasionally turn on by themselves, not turn off when instructed, not change temperature…
The controller finally packed in on the way home from my recent trip to France. This was rather annoying as I only had my summer gloves and was counting on the grips to keep my hands warm on the long motorway sections, early mornings etc…
So I decided to get rid of the rather useless controller and replace it with a much more simple and foolproof system that cold be repaired/bypassed at the roadside if it came to that.
Read on if you are a geek or are interested in the mod
The stock controller actually regulates the temperature of the grips by rapidly opening and closing the circuit at varying speeds. This works better than a current/voltage regulator because if you used that system you would just be dispersing the energy through resistors or a potentiometer, these components would also have to be high current rated (expensive)
As the rapid open/close method requires an IC, I decided to stay away from that system.
I instead decided to use a toggle switch to turn the grips on and off, via a relay connected to the headlight feed so that the grips could not stay on after the engine has been switched off. Also some noddy might decide to flick that nice looking switch on when you’re parked up in a bay. you then come back to a lovely flat battery but at least your grips are nice and warm.
For temperature control I knew I was never going to get good variation without using circuitry, but by switching the grips between a parallel and series circuit loop I was able to provide some sort of heat control
I used a double pole double throw switch, with an off position in the middle, to switch between the two circuits. I also wired in a couple of LEDs that light up when the grips are on. I was hoping to wire it so that the green LED would come on when the grips are in series, with a red LED to come on when the grips are switched to parallel. I couldn’t figure out a way to wire this so both LEDs just come on when the grips are on. If anyone has any ideas for this let me know!
Had them going like this for a week now and the results are great!
Couple of crap on/off pics…
Nice work. Where in the circuit are the LED’s wired? Are they rated for 12v? How are you actually driving them? The likely answer will be to use a simple current divider circuit. You’ll hook the LED’s in parallel to your existing circuits (after the switch between them - one current divider in parallel with each of your circuits), with a resistor to control the inrush current and provide the right current ratio (so you don’t have high current going through the LED itself). The resistance will control how much current is allowed through each side.
If you like, sketch up your current circuit diagram and I’ll try to point out what you need to make it work.
-simon
Thanks szymon, I’ll sketch it up today… They’re 12v LEDs and at the moment are simply wired up in parallel to the grips…
Interesting. I am using a single pole double throw switch and wiring a resistor in series with the grips to give me my difference in power output. I have bought some cheap under-grip heaters to try out and see if they work properly. I suppose you could have two switches working in tandem, one controlling the power level, and one controlling series vs parallel, so you could have a low level of power, and a higher level of power. Would be an interesting experiment to see what works, and how it works.
Just done a quick experiment with my Oxford heated grip covers (not proper grips, just covers that go over your existing grips. Wiring in series doesn’t really get any heat out of them at all - I might try again with the new under grip heaters I am getting, but at the minute still wedded to the resistor theory, i.e. wiring in parallel, but using an on-off-on rocker switch to be able to switch to a lower current supply (so less heat out of the grips. Have some resitors coming to play about with.
Just noticed that the ones I got from ebay are claiming to be 3W, whereas most others draw a current of about 3A. Hope they’ve made a mistake otherwise I am looking at £40+ for a set of 3A ones. Think they’ve made a mistake. How rubbish would 3W ones be…
Hmm not sure you’d wave to do the maths… 12ish volts, 3watts, rated for about 0.15 amps I think…
High load resistors cost loads because they have to soak up all the energy that you don’t want sent to your grips…
Damn good point. However, you can still get quite respectable high power resistors for quite cheap money on ebay.
I’m as cheapskate as the next biker. (Well, OK, not if the next biker is Alex_Gold, but that’s a different discussion ;-)). BUT - if there’s one thing you don’t want to economise on, it’s high power resistors which are pulling in power so that it doesn’t all go to your primary consumer. These things can get very hot, and the failure mode might be significantly worse than you might expect. Be careful what you buy, please.
-simon
OK, got the grips yesterday. They look and feel cheap, and the current wiring is possibly the stupidest thing I have ever seen. However, I am not complaining because all the cheapness is going straight in the bin, and they will be rewired to my needs and specification.
So. Power? They are neither 3A nor 3W, so the ebay ad lied (surprise). They draw 1.16A and are 14W grips. They seem to get hot enough on test on a bench supply, but they are never going to get as hot as, say, the Oxford Grips. However, I don’t think I need that level of heat (I never got onto high level for any period of time, and medium to low always seemed to do it for me. Time will tell.
Rewiring will consist of setting up a switched (relay so that the power is only on when the ignitinion is on) 4 way waterproof fuse box with two 6A feeds (3A should be sufficient for most things). Then I will wire in an LED switch for the grips (given the power of the grips, I won’t need a second setting so the dual switch is not required). Then fit the grips. All sounds simple, yes? Maybe.
