My Bike's not well :(
Evening all … my 2003 Yamaha R6 (fuel injected model) is not well !
Initially it threw an engine check light … then gave error code 46.
I got the bike home, and changed the battery for a new one, took it for a spin it was fine for 2 miles, then the dash just went blank, and the bike was ‘chuggin’ then almost lost all it’s power!?!?
It then all lit back up again like a chrismas tree … and I was able to get home.
Now home, the bike won’t start back up again, and it has given me an error code of 11
Aparently, from research 11 means “cylinder identification sensor failure”
Anyone have any ideas, know anyone in East London who can look at it for me etc ?
We are supposed to have a weekend of SUN, and my bike will be left sitting in the garage !!
I have absolutely no idea at all, except to say, did you get wet today or yesterday?
May be a damp thing. could be fine tommorow. Alternatively I could be completely wrong!
codes
11 - NO SIGNAL RECEIVED FROM CYLINDER IDENTIFICATION SENSOR (CAM POSITION SENSOR)
12 - NO CRANK POSTION SIGNAL
13 - AIR INTAKE SENSOR #1 - OPEN/SHORT DETECTED
14 - INTAKE PRESSURE SENSOR #1 - PIPE CLOGGED OR THROTTLE POSITION SENSOR (TPS) STUCK
15 - TPS - OPEN/SHORT DETECTED
16 - STUCK TPS SENSOR
19 - SIDE STAND SWITCH - OPEN/SHORT DETECTED
20 - ATMOSPHERIC SENSOR VOLTAGE & AIR INTAKE PRESSURE SENSOR VOLTAGE DIFFER GREATLY
22 - AIR INTAKE TEMP SENSOR - OPEN/SHORT DETECTED
23 - ATMOSPHERIC SENSOR - OPEN/SHORT DETECTED
25 - AIR INTAKE PRESSURE SENSOR #2 - OPEN/SHORT DETECTED
26 - INTAKE PRESSURE SENSOR #2 - PIPE CLOGGED OR THROTTLE POSITION SENSOR (TPS) STUCK
27 - OIL TEMP SENSOR - OPEN/SHORT DETECTED
28 - ENGINE TEMP SENSOR - OPEN/SHORT DETECTED
29 - DECOMPRESSION SOLENIOD (THERMISTOR) - OPEN/SHORT DETECTED
30 - MOTORCYCLE HAS OVERTURNED
37 - FAULTY LINEAR CONTROL VALVE
38 - DECOMPRESSION SOLENOID - OPEN/SHORT DETECTED
41 - LEAN ANGLE CUT OFF SWITCH - OPEN/SHORT DETECTED
42 - NO NORMAL SIGNAL RECEIVED FROM SPEED SENSOR & OR NEUTRAL SWITCH OPEN/SHORTED
43 - ECU CAN NOT MONITOR BATTERY VOLTAGE - OPEN/SHORT DETECTED
50 - FAULTY ECU MEMORY
Looks like a camshaft thingy ma doogit. Having the mechanical nuances of a 3 year old, I have no idea what that means… I notice theres no mention of error 46, and searches reveal nuffing. Take it to a yammy dealer.
Not very helpfull am I? Sorry
R
:slight_smile:
Bike didn’t get wet … it’s weird why it’s just decided to do it all of a sudden !
And as for Rossi … I’ve heard that one already ! lol
The cam sensor should be easy enough to change, on mine it’s bolted into the cam cover, not sure how much they cost as never had to buy one.
Right, well I’ve been let down by someone who could ‘apparently’ get it fixed … can anyone recommend a mobile mechanic … that knows the R6 … .and can fix my bike ?
Try this guy
http://londonbikers.com/forums/shwmessage.aspx?ForumID=50&MessageID=216846
