…started to go off for no reason the other day. Just now it kept going off after being armed.
Maybe it’s high time to get rid of it… I think this also means a hike in my insurance premium too… Does anyone know if it’s easy to get rid of it? I’ve been reading a bit and it seems it’s hooked up to the ignition as well as indicators (unsurprisingly…). Does this mean I have to re-splice the original wires back together? It’s a Datatool system 3 by the way.
Trace all the wires from the alarm box removing cable tyes and the tape holding them into the loom
two wires go to the indicator wiring just cut these off the original loom and insulate if necessary
There will be between and pairs of wires for the immobiliser bit you have to trace them to where the loom has be cut and a pair inserted remove them and rejoin the loom The cirkets in the loon cut will be one two or all three of :- power to the starter relay, inigtion power feed and fuel pump power feed
It takes me from one to three hours in a fully equipped workshop
^ What Dave said, he knows his stuff. You can do it yourself with a clear day ahead of you, a large dollop of common sense and a great deal of patience
Have you tried putting it into maintenance / ferry mode?
I seem to remember (from the one bike I ever owned with a
Datatool alarm) that if you put it into maintenace mode, i.e. with
the motion sensor deactivated, then when it auto arms after
that it will keep going into maintenace mode, it only switches
back to full mode if you arm it using the remote instead of leaving
it to auto arm.
i have found it easier before to just replace the loom on peds i have worked on. 2-3 hours racking my brain to make sure im cuting it right or a hour to unplug all the loom and replace with a new loom
On mine, the modes reset once the ignition is switched on and in maintenance mode the alarm will trigger and re-arm itself if you do not disarm within a few seconds.
I removed a datatool off of a zx7r - was pretty straightforward in my case - just traced each wire from the alarm to the point where it was soldered to the loom and snipped them off, reinsulated the loom and everything fine.
