I don’t understand the logic of these rules that don’t cover 125cc bikes - it’s the same with the hi-vis rules in france and I think the breathalyser rule too.
Are 125cc bikes immune to SMIDSYs, skidding and alcohol?
Agreed. The motorcycle industry argued that despite adding safety to bikes overall it would push the cost of entry level bikes beyond the budget of an average learner as well as drive up the costs of an average takeaway.
Having said that, with modern sensors and electronics, the technology must be cheap as chips, but I guess the IP licensing is a killer which should have been argued given the increase in production numbers as the technology would be mandatory for all bikes, they could have bargained the cost of that as well to make it affordable on any bike.
The trick to doing a stoppie is to get the brake on hard enough
to tip you up without the tyre losing grip, i.e. the problem was
always the tyre letting go. Now with modern rubber stoppies
are relatively easy. And with ABS you’re even less likely to lose
it, so easier stoppies?
Not that I do stoppies, honest, and I don’t think I have ever
ridden a bike with ABS.
But back to the original point… Why more rules it’s just turning
into a nanny state! Will super sports bikes have to have ABS?
I wouldn’t like ABS on my R6, will trials bikes and street legal dirt
I’d like to think I’m old enough and wise enough to look after
myself, I’m certainly old enough :crazy: and I resent any
government saying they know better. If you treat everyone
like kids they’ll behave like kids.
IIRC the proposal was that all 125s have to have a linked brake system. Still much safer than independent brakes, but nowhere near as expensive as all that is required is a couple of feet of pipe and a valve.
AFAIK
ABS works by monitoring the 2 wheels to check 1 isn’t spinning faster than the other. when it detects this it reduces the braking forces on the slower wheel to balance them
Mike, all the large bikes that I have ridden have had ABS. I can only think of handful of occasions when the ABS kicked in. Once saving a kids life when he cross a road between stationary traffic.
ABS handles the tiny percentage of situations that you can’t.
What will be the effect of trying to sell a non ABS bike when this new legislation kicks in 2016/17.
Will it mean buyers will stay away from second hand bikes withoutABS, regardless as to whether the new rules says only new bikes have to be fitted with the system?
Why would it? Did non-ABS cars become difficult to sell when ABS became a legal requirement on them?
I suspect some may only wish to buy ABS models, but I guess they’ll be counterbalanced by those out there that will insist that their riding skills are so good that they can brake better with non-ABS models.
