Hello all,
For the first time ever i am having a bike cut out on me.
I initialy started up my engine this morning and thought “that sounded a bit weird” but to be honest it was 6am and i wasn’t going to start tinkering then!
Low and behold on my way to work it cut out about 6-7 times! It mainly happened when i was in first and slowing down to the lights or something. I thought it may have been me the first time but then it has happened so many times i know it aint me!
All the other electrics are working it just seems to be ‘low on revs’ or something as it wouldn’t sit idle at the lights. However, when slowing down i ended up holding the revs to around 2000rpm and it stayed on and didn’t cut out.
When i pulled up at work i turned it off and on and at first it coughed and spluttered and then came to life and seemed to have no problems sitting idle. (At this time the temp was about 104 degrees).
The only thing i have noticed is the bike’s oil is just below minimum which i will top up when/if i get home!
any ideas what could be causing this?
