Does anybody know how i can quieten down my micron system, will a aftermarket baffle really quiet it down or not? the can exit measures 55mm across so pretty big and cant really find a baffle to fit and im scared that it will be to loud for a track day, someone help please…phil
its on a gsxr k3 1000 by the way
If you went to your local track when theirs a trackday going on they’ll do a noise test on it for you - wont cost anything.
Yep sorry mate a fail ,most day time Trackdays are 105db a friend had the same system came in at 109 db and just over 105 with the baffle.As the other dude says pop in and get it checked.
I have the Micron system on my 600rr, last tested at snett last year and with a cheap baffle in it made 103db, I have got it down to 101db with the baffle and the use of some wire wool
I have just ordered different type of baffle which I shall find out if it makes a difference on the 23rd at snett, also bear in mind that if your can needs repacking the baffle will not make much difference.
