To use the Garmin Tire pressure sensors you have to have metal valve stems or the sensor shreds the valve and you end up with a tire deflation, injury and or worse.
Can / should these be fitted to a sports bike. They seem more at home on cruisers. It’s not essential that I fit the sensors but I’m just interested.
Why do you want them, out of interest? I’ve got them on the 675 and I actually find them more of a hindrance than anything else.
Yes, I KNOW my tyre pressures are low!!! It’s a trackday and they’re cold! Stop showing me the warning light and defaulting to the pressure trip! Kinda thing
I have sensors which are compatible with my Garmin that replace the standard valve caps. They won’t cause a problem on track days as you can swap them out for standard ones or just don’t use the satnav.
I want to make a video for my blog and on the initial one I made I fitted them to the standard valves and if you do that and ride at any speed the sensor destroys the valve and the tire deflates and / or you crash. So I’m thinking about metal ones so I can use them.
Anything that relies on in effect opening up the tyre valve to monitor pressure is a very bad idea. As Dave has already said if they/or develop a fault then you have a leak and a deflating tyre.
