Yamaha YZF-R1, 06 model (11 Months old) bought Brand new on 1/3/07 -
well I have done 17,300 miles on My pride and Joy and enjoyed every mile apart from the 6 Pre-delivery inspection miles
was out Friday night just leaving Poppins to go to the square ,when i got there had noticed that my left boot was saturated only to find that oil was leaking from the bike looked that it was splashing too,
anyway had it recovered removed the bottom fairing cleaned the engine down to see where exactly the oil is coming from , i have identified that the oil is leaking from the generator casing from the gasket and not the bolts, i9 have checked the torque settings on the bolts and there ok,
Now if I’m right there shouldn’t be any oil in behind the generator cover from were it is leaking in the first place ?
which i have seen a diagram of the generator cover online, and it shows a O-ring that normally needs replacing if taken apart
has anyone come across this problem on this model bike and is there anything else it can be apart from replacing the O-ring behine the generator spindle and the generator Gasket
Seems to be no more than 2 hours work for the average good mechanic, is there anybody that might do this for me with out ripp off labour charges
I can probably get this done under my warrenty but can not wait a few weeks for my bike to be inspected then days fixing it ect…
I have taken Pictures of where the oil leak is coming from if needed then i’ll post them up
any help is appreciated as i need her on the road as soon as …
