maxed out
tryed to get on the LB SITE, THIS IS WHAT CAME UP, GOT ON IT NOW:D
Unexpected Problem Occurred! This error has been logged. If this problem persists please contact the web master. More Information… Detailed error information follows:Exception Type: System.InvalidOperationExceptionException Message: Timeout expired. The timeout period elapsed prior to obtaining a connection from the pool. This may have occurred because all pooled connections were in use and max pool size was reached.Exception Source: System.DataException Target Site: GetConnection---- Stack Trace ---- System.Data.ProviderBase.DbConnectionFactory.GetConnection(owningConnection As DbConnection) (unknown file): N 2499521 System.Data.ProviderBase.DbConnectionClosed.OpenConnection(outerConnection As DbConnection, connectionFactory As DbConnectionFactory) (unknown file): N 1645767 System.Data.SqlClient.SqlConnection.Open() (unknown file): N 00258 Apollo.Users.Security.CollectRoles() (unknown file): N 00233 Apollo.Users.UserServer…ctor() (unknown file): N 00035 Apollo.Server…ctor() (unknown file): N 00093 Apollo.Server…cctor() (unknown file): N 00031(Outer Exception)Date and Time: 03/07/2010 20:52:21Machine Name: NS202902Process User: NT AUTHORITY\NETWORK SERVICERemote User: Remote Address: 82.5.82.251Remote Host: 82.5.82.251URL: http://londonbikers.com/Default.aspxNET Runtime version: 2.0.50727.3607Application Domain: /LM/W3SVC/2109864197/Root-1-129226556440863750Assembly Codebase: C:/Websites/64bit.londonbikers.com/bin/londonbikers.DLLAssembly Full Name: londonbikers, Version=1.0.3822.35495, Culture=neutral, PublicKeyToken=nullAssembly Version: 1.0.3822.35495Assembly Build Date: 19/06/2010 20:43:10Exception Type: System.TypeInitializationExceptionException Message: The type initializer for ‘Apollo.Server’ threw an exception.Exception Source: londonbikersException Target Site: GetConfiguredSite---- Stack Trace ---- Tetron.Logic.Functions.GetConfiguredSite() (unknown file): N 00026 Tetron.Controls.RhsColumn.Page_Init(sender As Object, ea As EventArgs) (unknown file): N 00140 System.Web.Util.CalliHelper.EventArgFunctionCaller(fp As IntPtr, o As Object, t As Object, e As EventArgs) (unknown file): N 00025 System.Web.Util.CalliEventHandlerDelegateProxy.Callback(sender As Object, e As EventArgs) (unknown file): N 00042 System.Web.UI.Control.OnInit(e As EventArgs) (unknown file): N 00132 System.Web.UI.Control.InitRecursive(namingContainer As Control) (unknown file): N 00143 System.Web.UI.Control.InitRecursive(namingContainer As Control) (unknown file): N 00391 System.Web.UI.Page.ProcessRequestMain(includeStagesBeforeAsyncPoint As Boolean, includeStagesAfterAsyncPoint As Boolean) (unknown file): N 01477---- Collections ----Cookies IF_LastVisit 02%2f07%2f2010+21%3a51%3a22 __utma 32517155.1952009389.1261958919.1278026391.1278103837.77 __utmz 32517155.1278012618.75.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none) TetronPersistantAuth blackbirdxx ASP.NET_SessionId v0nfyg45yops2yvpwilvym55ServerVariables APPL_MD_PATH /LM/W3SVC/2109864197/Root APPL_PHYSICAL_PATH C:\Websites\64bit.londonbikers.com\ CONTENT_LENGTH 0 GATEWAY_INTERFACE CGI/1.1 HTTPS off INSTANCE_ID 2109864197 INSTANCE_META_PATH /LM/W3SVC/2109864197 LOCAL_ADDR 91.121.167.103 PATH_INFO /Default.aspx PATH_TRANSLATED C:\Websites\64bit.londonbikers.com\Default.aspx REMOTE_ADDR 82.5.82.251 REMOTE_HOST 82.5.82.251 REMOTE_PORT 55681 REQUEST_METHOD GET SCRIPT_NAME /Default.aspx SERVER_NAME londonbikers.com SERVER_PORT 80 SERVER_PORT_SECURE 0 SERVER_PROTOCOL HTTP/1.1 SERVER_SOFTWARE Microsoft-IIS/6.0 URL /Default.aspx HTTP_CONNECTION Keep-Alive HTTP_ACCEPT image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/x-ms-application, application/vnd.ms-xpsdocument, application/xaml+xml, application/x-ms-xbap, application/x-shockwave-flash, application/vnd.ms-excel, application/vnd.ms-powerpoint, application/msword, / HTTP_ACCEPT_ENCODING gzip, deflate HTTP_ACCEPT_LANGUAGE en-gb
Just a meer glitch in the software i suspect, i think you will find all is back to normal now.
This seems to be happening more and more since our switch to a French server/ISP:P
