I’m trying to get a homemade tail tidy together for my Husqvarna SM, but am having problems connecting the LED rear light I bought for it.
I’ll be the first to admit that I’m a bit of a dunce when it comes to most of this kind of stuff, especially electrics :unsure:
So forgive me if my explanation isn’t that great, but I’d appreciate any help you could give.
I did the following:
removed the stock rear assembly and unplugged the rear light and indicators.
tested the new LED rear light on a variable voltage power adapter (that I use to power a small guitar effects unit) - everything was okay i.e. two different levels of brightness when switching (what I believe to be) two live wires, one for the running light, the other for braking.
There are three wires from the stock rear light to the connector, I took note of their colours and what I assume their function is:
Green - earth
Yellow - live for running light
Blue - live for brake light
This is how it is on my LED light.
replaced the ‘plastic connectors’ that joined the rear light to the loom (and vice versa) with new ones, ‘male’ on the loom and and ‘female’ on the stock rear light and LED light making sure that I wired the plastic connectors so that the coloured wires were in the same place on both the ‘male’ and ‘female’ connectors.
it was time to test the connections - the stock light works okay with the new connectors, although there is not much difference between the running and break light brightnesses.
But the LED light did not light up at all
Strangely (to me), when I attach the blue wire from the LED to the green one from the loom and then the yellow wire where it should be (LED to loom) there is light from the LEDs.
Note.
There is enough power in the battery.
The LED light DOES work (both running and brake).
I assume that the green loom wire is earthed correctly as the stock rear light works okay. This could be the culprit, but I don’t know how to go about fixing the situation.
I don’t have money to buy a multimeter BTW
I thought this would be a simple swap over of parts like it, basically, is with LED indicators, but not yet
Any suggestions or requests for me to carry out further tests would be welcome.
Thanks.
G
Here are some photos.
(the stock rear assembly)
(what I’m aiming for)
(the new ‘plastic connectors’ on the LED light and loom wires)
