Instructions show its the tyresize you have to check…
It shows that you should mark a point on thewheel/tyre (I.e Valve) push the bike forward until the valve is in the smae place and measure the distance on the ground…
is the speed set in KPH?
Are the settings set in another measurement setting? Like cm, instead of meters, inches instead of mm’s. You get the picture.
Might need some translation to get correct value for the 197/1970 measurement
:pinch: sorry, I was thinking something completely different.
Are you required to set the distance of the speedo pickup from the centre of the hub?
How will speed be calculated by knowing the circumference alone? (kind of a question for Koso, I know)
its because your useing the crank sensor and dileing front wheel mesurement you nees to be puting in the mesurement from one rotation of the crank witch would be to much hassle to work up lol just run a maganet to the wheel
