klunck/knock coming from my forks
Well at first i thought it was my headraces. Had them changed still there, tightend my engine mounts except the castle nuts (dont have the tool) front subframe bolts, fork clamps, yoke, and backed out the top adjusters on the forks half way yet still there is a knock like its coming from the top yoke or near by.
have been told its because my forks need a service. is thatrright?
also check your brakes… could be disk/pad movement
checked new pads in last week there is a slight amount of rotor float but only when the front brake is on. this big noise is much highier by the frame/yokes
Sounds like internal fork bushes. If it is, it’s not desperately serious, but the forks will need stripping to sort it.
sounds about right then havnt had them serviced in the 16k ive had the bike.
How much of a job is it to service the forks i.e oil bushes etc?
fairly easy job to do the forks, just make sure you do one at a time so that you don’t inadvertently mix up the parts from one to another.
