Well just gone to get the KH400 out and tidied up ready for the summer and hopefully this weekend for the Kawasaki day at the ace when I find the front brake is squirting brake fluid out the bleed nipple…hmm never had that before…and yes it is screwed in…very odd, no time tonight so will have to wait until saturday…I love old bikes…
They can corrode too, both the caliper around the bleed nipple and the nipple, I usually change them when they look the slightest bit dodgy, usually only a couple of pounds each.
yes hopes its just that…as I say i have a spare but will bleed the thing anyway…only been off the road since last year…got to fit new indicators though all round…prefer it with indicators rather than sticking your arm out…
“Caution — braking performance at beginning of the apllication may change with wet brake disc” :w00t:
the normal “cure” is to fit braided hoses and fresh fluid, and sintered brake pads, also clean out the calipers especialy the seal retaining groove, if the problem is still there, it may need an overhaul of the master cylinder.
found the fault after drying out the garage, the prvious owner had done a botch job threaded the bleed nipple and I guess just stuck it back in with loctite… but I have a new one…wonder if I could not re tap it and see if that works but I doubt it…helicoil will work i guess but think the caliper is basically US,
