k7 750 shock on a k4 600
has any one got any idea if this can be done ???
and is it worth doing???
Does not fit
Are you sure ? :slight_smile:
no, but I know they are not the same shock.http://cgi.ebay.co.uk/SUZUKI-GSXR-600-750-2004-2005-K4-K5-REAR-SHOCK_W0QQitemZ260217354306QQihZ016QQcategoryZ10534QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/2006-2007-Suzuki-GSXR-600-750-k6-k7-Rear-Shock_W0QQitemZ260217048084QQihZ016QQcategoryZ10534QQssPageNameZWDVWQQrdZ1QQcmdZViewItemThe resevoir is in a different possition. Might not fit. I don’t know about the distance between top and bottom pivot, but you may as well just go for the OEM item.
[quote]
Nuts (08/03/2008)
Well why are you giving Advice then :D:)
Stick to Bowling ;):P:)
furry muff. Why don’t you stick to Area 51
Is that a Bowling term? :ermm:
Hey Frogga I doubt the K7 shock will fit if all you want to do is swap them over and hope everything matches up, but with the right tools a decent workshop and a knuckle bleeding attitude anything can be made to fit it just might not be worth all the effort :smiley:
Why not try something like a Hagon shock there better than most OEM shocks (just) are cheap enough and will slide straight in.
:wink:
