Dev Chingford is not too bad, he u turn spot they usually take you too is sightly off camber but that road that I think you went to is rarely used. Just make sure you leave room after the push around for the U turn - I backed up my bike so it was nice and tight to the kerb! Also found that the trick of focusing on a point over your shoulder as you turn helped massively.
I was shown a while back the worst u turn road they CAN use on Chingford routes, can’t remember the name of it, but I did post it here a while back so you will have to search but I practiced the u turn on that road loads (narrow with a strong camber).
apparently that road is used for U’s very rarely, but if you can do it there you can do it anywhere.
Saying that I did 2 bike tests at Chingford and passed 1st time on each - neither went near the road in question !
