Right, went to start bike but as i was doing it the bike seemed to just start dying.
It was trying to turn over then nothing. All i get now is the clicks from the starter (i think).
all lights work ect…
took the batt to the shop and charged it for 6 hours. put in the bike and it done the same but this time it went from trying to start to clicks in about 2 minutes.
Does the batt need replacing or could it be something else?
the battery is about a year old. (unless he ripped me off)
6 hours would’nt be enough iof it was being charged on a trickle charge like an optimiser needs to be at least 24 failing that then yes i’d say battery is kapow
if the battery is reluctant to hold charge, try dropping it on the floor from about a foot. it supposedly knocks sulphates off the plates? i’ve never tried it myself, was listed in tips and tricks in this months RIDE… so it could well be total rollocks
You could buy (or find someone on here who has one) an optimate and put it on that overnight. That can recover batteries. However if the battery is a few years old and knackered it may be less hassle just to replace it. Battery problems and a bike failing to start are very irritating.
So can you not buy the old type batterys anymore? i used to find them better just top up the acid then charge and go…so much easier than fartarsing about wiv these sealed ones:D
have you tried push starting the bike? if you can start it that way then you can check the charging circuit with a meter. Failing that a new battery is probably the way to go and if you have the option then a battery tender for times when you are not using it for a couple of days (in very cold weather that can be all it takes to run a battery down) it is important to check the charging voltage as even sealed batteries can be boiled dry if overcharged
the other thing to check is whether the starter is turning at all? or is it jammed.
the cold can kill off even a good battery if it isn’t fully charged, push starting an in-line four shouldn’t be hard give it a go I’ve had a couple of batteries give up the ghost in very cold weather, sometimes you can recover them other times not, you can have batteries delivered so no need to go out looking too far afield
