Right bit of a weird one this but…
My bike stalls quite frequently when I pull the clutch in… it’s irritating and it means I have to re-start the bike 7-10 times on a commute
But that’s not the issue (no one still has managed to figure out why it’s doing it, yet). The more immediate issue is that I just noticed that my Oxford Heated Grips (which I haven’t used in months) now don’t work. The blue 30% light will randomly come on when I haven’t pressed the On button and when I press it On I cannot move the heat up or down and the grips don’t get hot.
Now normally I would have said that it’s the grips fault but last winter I had to change my R&G grips for pretty much the same reason
Both grips are plugged into the battery so could the constant changes in charge be causing my grips to fail?
