Looks quite good from initial research, and I’m probably going to get it when it hits the UK in a few weeks (especially as I’ve been in the process of re-doing my existing K1 setup due to some issues).
I have both a K1 and a C5
Both in a box waiting for me to fit either one on the triumph
The K1 can suffer from electrical interference
And vibrations where the cables work loose
The C5 works great but doesn’t like recording on a 10min loop
They are both micro SD card fickle
You have to fit what’s reconvened and use a sd card formatter not just use Windows to format the card
@Wise agreed re issues on the K1. My front one also keeps cutting out. K2 is a brand new system/board/firmware, so hopefully has resolved things. Connections are now also backed with a screw to keep in place.
The DVR is now IP65 rated too.
Also comes with mounting accessories, which is good!
