Okay all you petrol heads out there…or you may just want to keep your licence
We now have the Inforad Camera locators in stock at Great Portland Street!!! The unit only retails at £99.95…other systems on the market which do the same thing retail at over £300!!! and unlike them the Inforad system is a very trick bit of kit…its tiny!!! and completely flexible so you can mount it neatly on the dash out of the way oh yeah… it completely road legal too We were selling these at the NEC at an average of 20 units a day you really neeed to check this kit out…the ‘trick’ factor alone makes it worth it!!
Ive put the link below…but I dont do computers so might not work in which case just go onto Datatools site or pop in as I have them here!!!
considering around london and the nice roads we like tend to have speed cameras so… you might get used to the light being on…
hmmmMMm… its a thought… am considering getting the t-mobile phone with sat nav which has all the speed cameras on it anyways… then mount it onto my bike other trips around london rarely speeding and usually know where the cameras are…
I need one. My licence is the cleanest it has ever been and if I want to keep it that way I need to avoid Police traps, speed traps, speed cameras, but not specs whoever thought that capturing the front number plate shoudl be shook by the hand.
It is GPS based so it only comes on if it knows there’s a camera there - i.e. no false alarms. It is green most of the time and then goes red if you’re approaching a camera and flashes red if you’re approaching over the speed limit. I’ve had mine since the bike show and it’s great. The only thing that confuses it a bit is when you’re somewhere like the M4 flyover section above Chiswick and it detects the speed camera on the A4 below you.
If you’re approaching the Hanger Lane underpass going westbound it detects the A40 camera much earlier than normal because it knows that you’re not going to get a reception whilst you’re under the tunnel or for a few seconds after you come out. Nice touch, I thought.
Trying to work out where to put the receiver can be a bit tricky at first. You can’t have it under the seat (line of sight to the satelites required). I eventually mounted it on top of the brake fluid reservoir and it blends right in being black. You wouldn’t even notice it.
