Yeah I’ve tried that but it’s really hard to explain… There’s a sort of downward tube section, 2 or 3 inches, that protrudes down into the tank from the filler cap…
So when I squirt a bit of petrol in the top from the ‘hover’ position, it takes the petrol a few seconds to bubble down and displace the air round the other side of the tube section…
A mk1 Fazer has only 18 litres, the mk2 is 21. This is due to the filler pipe extending down into the tank. On the mk2 they shortened this pipe giving extra capacity. There is a way to change the mk1 but involves very carefully drilling a hole in the filler pipe near the top. You need to make sure you don’t get any bits falling into the tank but this will give you a 21 litre capacity (or thereabouts). You can then carefully fill the tank to the top as the hole allows air to escape.
what Art says, I never fill up right to the brim, but leave that bit where ya stick the nozzle in free (that tube you describe further up).
Did however manage to fill up 18l in my Fazer MK1.
the tanks are 21l, of which 4l are reserve.
Also put it either on center stand or sit on it when filling up, keeping it straight. I do the latter
smiled, you can pull the nozzle out as far as you want on a Fazer, it won’t fill beyond the filler neck unless you make an escape for the air.
Art, the difference between mk1 and mk2 Fazer fuel tanks is only the length of the filler neck, it’s shorter on the mk2 effectively increasing the capacity so there’s no harm in making a way for the mk1 to fill more.
Sorry I should have stated that centre stand and holding the nozzle above the level of petrol was a proviso.
I do realise that petrol pumps have a small breather hole that shuts off the flow valve when it gets blocked.
And I understand that I need the filler cap to be at the highest possible point in order to achieve maximum fillage
It was just the small air gap at the top that I was concerned about
