any of you have experience in de restrict a restricted bike? Yes, my bike was restricted. I just had to remove a metal plate that stops the throttle twisting back all the way.
if a bike is restricted to 33bhp, is it legal to derestrict it? Yes, its 100% legal.
as i understood searching on the web most restrictors are placed in the carbs inlets so i think just take them off and that’s it…
On ebay though i found a derestriction kit fo 50 pounds, what’s all about??? Restrictor kits are required in the UK if you are under 21 years of age or if you have done a restricted licence. This will change soon as new stricter laws are coming in. A restrictor kit for my bike is approx. £150. There are different types; but your right old 400s are usually where the carbs are. Its just a washer type ring that reduces the air intake.
Don’t let the bike being restricted to 33bhp put you off. Whatever has been done to restrict it can be reversed. The only way you will know how its been restricted is to get the bike home and take a look. If the bike runs well and you can get it at a good price get it.
Don’t commit to any parts before you buy it as you may not even need them. Any good mechanic should be able to derestrict it with an hour’s labour and parts if required. Talk to Adz on the forum he can advise you better than me.
Theres tons of hardcore 400 riders on here that know everything and anything about greys. Someone there should be able to give you a detailed break down on how to do it.
I think theres even a mods section which details how to de restrict the RVF 400. ( at least there was when i had mine)
the only thing that put me off is the restriction… Don’t let that put you off its easily taken off
I found out that the kit he sent me is a “derestricted CDI” so it should be quite simple to just replace it… Its just as simple as taking the old one off and plugging that one in.
if restricted, does it appear in the v5, should i advise dvla of the mod? No it doesn’t appear in the v5. No, there is no need to.
I’d go for it and “worry” later about derestricting. It should be beautifully run in by now.
The CB400 was imported into this country in the '80’s and was popular with couriers doing central London work for a while (when they got cheap secondhand) so there ought to be plenty a used spares around.
From (unreliable) memory the engine and drive train were pretty solid but rest was pretty average and the finish was not up to Honda’s normal standard. I have a feeling that I read somewhere that a lot of the not so good bits were outsourced and pattern parts replacements were better than the original bits.
yeah that restriction (japan law)would cut the rpm in 6th gear aournd 5000 6000 rpm i found out, my bike has the restrictor washers so it only revs up to 6 hardly 7k rpm in all gears instead of the 11k…
Two different conversations going on here. The 33 horse power restriction is a kit added to the bike to make it comply with UK restricted license regulations. It is not legal to remove this unless you have a full unrestricted license. Japanese grey import bikes have top speed limiters, which work differently depending on make, model and year. How to derestrict will vary accordingly, but a naked 400 won’t do much more than 112mph anyway. How often do you ride faster than that?
the Bros/Hawk is restricted to 116mph, and is done in the rev counter (so im told, not sure how) by when you hit 116 it puts the rev limiter down to 5k untill you drop down the speed.
