I can hear a tapping/clicking noise coming from the front end when braking on my Sprint. Upon inspection there seems to be quite a bit of movement in the outer part of one of the front brake discs, more than the other front disc. I was just wondering how much movement is there supposed to be?
Yup, checked everything else, the only thing that has any slack is the left brake disc. It definatly moves more than the right hand one, might pop to my local dealer and get them to give it a quick check for me.
i had this on the beamer. it was the rivets holding the floating disc that were worn. i got them replaced and from memory, they were about £5 each (plus fitting).
Triumph discs are notoriously loose. I worried about mine on the Daytona, so bought a low mileage set that turned out to be just as bad. They leave the factory like that.
Couple of other things you could try though… Clean the brakes thoroughly, if one of your pistons is stuck on even slightly it will push one of your discs over a fraction and cause it to click.
Also, if that doesn’t help, then slacken off the pinch bolts on at the bottom of your forks and pump the front suspension aggressively a few times, then retighten the pinch bolts. This ensures the forks are aligned with the discs.
I also discovered that pushing a wide bladed flat screwdriver into the rivets on the brake disc and rotating them slightly lessened the noise.
Might try rotating the rivets, I don’t mind giving things a go, but I’d rather not try things that could screw it up in any way as I’m not over confident mechanically as much as I would like to be
