This is an extract from a few emails from my mates…2 questions
Are tyres meant to be hot to the touch?
Are tyre pressures and guages affected by altitude, and how do you adjust if they are?
Any answers?
The extract…
I just got back from a quick trip to Thonon on the bike and decided it was time to lube the chain. So I stuck the bike on the centre stand and started spraying, only to find the back tyre was crazy hot - maybe not enough to scald your hand but still bloody hot enough to require putting my gloves on to continue to turn the wheel/chain. I guess the tyre pressure might be low - even though they sort of look OK - its at least a couple of weeks since I last checked the tyre pressures so just in case I will make sure I check the pressures first thing tommorrow when they should be stone cold.
Anyway is this normal? - I have never noticed my tyres ever get more than slightly warm before now?
Reply
Yes - wait until you figure out how to use brakes then check out the discs ¬!
Hot tyres are caused by
low pressures
Enthusiastic driving
If you have hot tyres (as in hot to the touch) & brakes that will burn you I would say that’s normal.
Tyre pressures are really important & should be checked cold, however be aware that you can ‘tune’ your tyre pressures to your style of riding. In Winter, (ie cold) if your tyres are normal pressure it will take a certain amount of time to get them warm & so work effectively.
By dropping your pressures (max 5 psi as you just don’t ride hard enough to drop lower than that) it will create more friction & so get the rubber up to temp faster.
A good tip is that after a run your tyres should be the same temp & feel the same. But you have too check this immediately you get off the bike.
Reply
Thanks I’ll check what the tyre feel like after my next longish run.
Pressures were bang on this morning indeed the rear was 2lbs high so I let some out. I also checked them both thoroughly and there is no sign of any damage or abnormal wear. Looks like the scrub marks seem to extend slightly further up the sidewall on one side of the rear tyre than the other but again its only marginal.
Its weird if hot tyres are normal I am surprised I have never spotted it before. I must admit I normally find time for a cup of tea before attempting to lube the chain after a longish run so maybe it always had time to cool a bit.
One question I had was how do pressure gauges in a footpump work? and are they affected by altitude? I know things like eggs take loads longer to warm up when cooked here because of the altitude and wonder if I need to adjust my target tyre pressures because I am so high up? If so, which way would I need to adjust the pressures?
Anyway for now things seem Ok with the bike so I guess I’ll just keep riding whilst the weather is OK - although it was cold enough yesterday to need my winter gloves.
