HONDA AVERTO ALARM MANUAL
Has anyone got the installation manual for this alarm? I need the wiring diagram. The full manual would be useful though.
Regards,
BM
are you still struggling with this alarm business :blink:
:smiley: Not so much struggling…I’m waiting for the alarm to arrive from the US. I think customs has it.
While I’m waiting I want to use the Averto connector instead of cutting into my original wiring.
Know anybody who might have that sort of info. The connector has exactly the same wire colour as the indicator positive leads plus it has a green wire assuming ground and a positive red and negative black/white wire which should allow switched ignition.
But it would help with the manual.
Regards,
BM
sorry as you have a newer bike than me im not very helpful :ermm: why not buy a (hanes) manual for the new one.
also might be a good idea to post on hornetsnest
Can’t you have to be a member on Hornet’s nest. Haynes manual…don’t really do my own repairs so not worth it for the money and it won’t have the details on the Averto harness anyway.
Regards,
BM
hi mate… only thing i could find to help was the wire harness schematic here
1 RECTIFIER ASSY… REGULATE £185.29 1
2 DIODE ASSY… THREE WAY (SUMITOMO) £21.23 1
3 HARNESS. WIRE £305.19 1
4 SUB HARNESS. INJECTOR £172.87 1
5 CAP. DUMMY (4P) (RED) £4.61 1
6 CAP. DUMMY (6P) £6.92 1
7 SENSOR COMP… BANK ANGLE £141.40 1
8 COLLAR £4.63 2
9 GROMMET £2.31 2
10 HORN COMP. £56.32 1
11 RELAY COMP… WINKER (MITSUBA) £37.72 1
12 SUSPENSION. WINKER RELAY (MITSUBA) £2.42 1
13 RELAY ASSY… POWER (MICRO ISO 4P) £9.41 4
14 SUSPENSION. RELAY £2.42 2
16 RUBBER. STOPPER £1.34 2
17 STAY COMP… REGULATOR RECTIFIER £13.11 1
18 RUBBER. MOUNTING £0.83 2
19 BRACKET. PGM-FI UNIT £15.24 1
20 STAY. ELECTRONIC CONTROL UNIT £4.10 1
21 COLLAR. FAIRING SETTING £2.55 2
22 BOLT. ONE WAY. 6X12 £1.06 2
23 BOLT. FLANGE. (DR) 8X14 £0.87 1
24 WASHER B. HANDLE HOLDER SETTING £0.79 2
25 BAND. WIRE HARNESS £3.14 1
26 SCREW-WASHER. 4X22 £0.72 2
27 SCREW. TAPPING. 5X12 £0.40 2
28 NUT. FLANGE. 6MM £0.53 2
29 BOLT. FLANGE. 6X28 £0.80 2
30 BOLT. FLANGE. 8X12 £0.80 2
31 FUSE. MINI (10A) £0.56 5
32 FUSE. MINI (20A) £0.56 3
