the missus honda nc30 has a warped front left brake disk & need a replacement.
does anyone know if cbr600, 400 or other models fit the same? also are the disk handed left & right or can you use either side.
cheers for any info:)
would have thought a CBR400 disc would fit? google up the specs see if they are the same zize?
Don’t just check the size, off sets and bolt holes vary too.
Try to match the part numbers using the on line parts books. Don’t forget the pattern part dealers are out there too and some of the stuff is better than the OE tat.
