Help please
Just fitted a pair of Carbon can Co. cans. They say removable baffles,
how do you get them out?
is it just a matter of drilling the rivit out at the end and pulling?
can you refit the baffle once it has been taken out?
Many thanks:)
If they are the same design as Remus ones you need to drill out the pop rivets and when you replace them you need to use a self tapping screw or get a friendly engineer to tap the baffles out to suit something like an M4 screw:)
I had a CCC stainless can on the CBR6, very nice noise. It had a little hole underneath the outlet allowing you to get to the retaining screw, check yours before you start drilling things!
