Help Installing a Booster Plug - k1200S
I’ve about had it with Park Lane BMW and have decided to fit a simple booster plug to even out the fuel mixture on my rough running '05 k1200S.
Anyone have any experience fitting these? I could do with a bit of a hand.
I don’t mind giving you a hand over the weekend but isn’t it three wires?
There are a lot of videos on youtube also, should make life easier if you want to go it alone :slight_smile:
Had to giggle at the install manual - “Make sure that none of the four small idle tubes aee squeezed flat by the BoosterPlug module when you reinstall the tank—otherwise the bike will run really weird”
