I have 4 years of experience recording asphalt and I’ve used 10 different cams in that time.
Most of these can be found at Actioncameras.co.uk.
ActionCameras was kind enough to give a 10% discount code
Discount code: P18710
Drift Ghost HD - From £250
Pro: Screen, water proof, durable, video tagging, remote control, wifi, 3hr battery.
Con: Buggy Android app
Comment: This is probably the most feature rich camera. Very useful tagging feature which saves you time looking for footage and clearing your SD card
Contour ROAM2 - From £170
Pro: Easy to use, Waterproof, very durable, laser view finder.
Con: Least impressive video quality of the 3. But still good.
Comment:
GoPro Silver - From £200
Pro: 2.5hr battery, best video quality, wifi
Con: No screen, needs case to be rain proof, not aerodynamic.
Comment:
Do you want cheaper?
Take a look at the Drift HD 720. It’s a very capable camera with a remote control at £100.
YouTube is a great place to research these cameras.
Here is an accident that probably would of went 50/50 if it wasn’t for the camera.
http://www.youtube.com/watch?v=YqnRIeRT2hs
THINGS TO CONSIDER WHEN BUYING
You will be able to YouTube or Google information on the following
Video tagging: This feature allows it to continuously record without wasting SD card space. Eg: You press the tag button and the camera will store the last 2 mins and the next 2 mins. (times can be changed)
Low Light Recording: Check to see how well your desired camera handles low light levels (unlit roads can be a problem)
High Definition: HD cameras are good for clearly capturing the small details around you like numberplate.
Battery Life: Dedicated helmet cameras often have around 2.5hrs battery life, but always check.
Mounting: How/where do you intend to mount it? Helmet is generally best due to less vibration.
SD Card: Check if your camera can accept 16GB/32GB cards. Best to buy the biggest genuine SD card. Look out for fake cards of else you’ll have corrupted videos.
SD Card CLASS: If you plan to record at 1080p or 720 @ 60fps then you should get yourself at the very least a Class6 SD card. A slow SD card will have issues keeping up with the data rate.
Wide Angle: wide angle cams are great for capturing things around you (like the car swerving into your lane) but the more wider the the view is, the more fish eye your video will look.
