Actually just found this one!!!
so typically (option2) you will receive two brake lines and one double banjo bolt:
also a set of nice new copper washers!
Nice…
also order some of these if you’re replacing over fender lines
Makes a neater job than the existing hose brackets will
That’s great, thanks mate!
definitely go for the racing set-up…
I only noticed a bit more difference - nothing to rave about for sure. once or twice I’ve locked up the front when breaking harshly and it seems to be a bit easier to do with them… but I would say that was 90% my fault panic braking
As a girly point of view, not technical!
I had really really bad brakes, changed to Hel lines.
Made a difference, brakes are now just bad!
Hahaha… from really bad to bad there is an improvement!!!
So, has anyone used Wezmoto? Are they considered good?
It’s £60 for all three lines…
Not bad I guess…
yeah man wexmoto good, pretty sure theyre on my mates 400 - no problems with them at all.
I have Goodridge race setup hoses on mine with 5.1 DOT fluid (two lines to the calipers from the master cylinder) and they’ve been fantastic. I think the brands are more or less the same, and race teams will put whatever brand sponsor them on their bikes. Like Samco cooling hoses too
