How difference do they make on the bike?
Is it worth the expense?
*Please redirect me if there is an existing post…
yes, they are worth it for two reasons
you dont need to change them again unlike rubber hoses which have a service life of about 3-5 years according to most manuals.
rubber hoses expand a little when you brake whereas braided lines do not so you will get a potential performance increase in braking.
i say worth it alone on point 1 imo
Indeed…
You would do both front and back, right?
I’ve fitted braided lines to replace old OE rubber hoses.
I’m not a racer/trackday person so don’t notice the kind of improvements in performance that get exposed in a more extreme track environment - I was just replacing old rubber lines.
If you are on a budget and the rear rubber line is in reasonable condition then just replace the front brake lines.
well if the price was good otherwise im mainly fussed about the front - it does look better though so…bling bling!
i would get the line setup on the front that goes to each caliper form the master cylinder too if it were me.
If you are doing the bleeding yourself i would recommend a plastic syringe and inject the brake fluid up through each bleed valve on the calipers - makes life a lot easier - only a few quid on ebay too.
That was the next question tom… whether to go with on the front or racing setup.
Won’t be doing the bleeding myself, I would probably get someone else to put them on.
Totally agree with the separate line set-up (originally had over mudguard config)
Rob (mechanic mentioned in the praise section) fitted mine because I’m not overly comfortable with brake bleeding
the change did make a noticeable difference over the stock lines on my 600RR
Sorry to re-iterate, just to get it straight…
You suggest going with the front over fender set up rather than the racing right?
any recommendations for the brand? wezmoto, goodridge, galfer?
I would imagine HEL!
Ive had HEL, Wezmoto, Goodridge lines on various bikes and to be honest they were pretty similar. The goodridges i had on an old gsxr were about 5 years old and looked mint still though.
I have read in other forums that you need to get to top range of Goodridges to be as good as the HEL ones.
I could probably dig up the post somewhere…
The HEL stuff i fitted to a VFR a couple of months back was very good quality i must admit - but the Goodridge stuff i had before was of equal quality - im not sure what range it was from!
found one more UK brand Venhill, seems they were making braided lines for 40 years. The bigger the choice - bigger the headache
ah yes, Venhill make some really good stuff - any of those lot will sell good products though - i wouldnt get too caught up on brand names.
Thank you tom22!
Apologies to chris2332 for invading his topic :hehe:
No worries at all…
The more information, the better
No, I swapped out the over the fender set-up for separate HEL lines, made a big difference
yeah man go race setup for sure.
Ohh ok!
Do you happen to have any photos to see the difference???
