heathrow crash!
Off-roading a 777. Anyone beat that? Did bloody well to get it down in (relatively) one piece and with only minor injuries - only one lady detained in hospital overnight apparently - and no loss of life among the 150 or so people aboard. :slight_smile:
I hope to never be in a plane where it is possible to photograph the undercarriage assembly without the fuselage or wings being in view!
The plane losts the undercarriage, had one set pushed up through a wing, dragged along the ground for several hundred yards supported by the engines and engine mountings - it is not going to fly again!
well im back at work tomorrow…see if i can have a chat with some of the BA head setters…see what they say…there bound to be gossiping…;).
what do you do at gatwick kevsta?
smiled:D.
It doesn’t look that bad, I’m sure the marks will polish out :laugh:
right now, everyone knows how unlucky mr smiled is (dont ride too close to him)
The very night before this happened, i was talking to him, laughing saying how jinxed he was, and we were talking about air crashes, and he was saying about some aircraft that take off from Heathrow, then next morning, plane crashes at heathrow!!!
you make up your own minds people…
IS smiled jinxed?
The papers today are saying it was system malfunctions, but with all the backup systems, and on such an ultra modern aircraft, i find this very hard to believe…
Also, an experienced BA Pilot, wouldnt stall an ultra modern jet on landing.
He also would have known he was low on fuel, and if that had been the case he would have been able to radio through, and glide in for a safe landing.
The planes dont just run outa fuel, then fall from the sky
There were also reports of Canadian geese or something, but even at this, the event of them taking out both engines, is very unlikely…
I spose wind sheer is a possibility, but with such a huge jet, enough windsheer to cause it to hit the deck? with many other aircraft having already landed just minutes before?
So let the conspiracy theories roll… :smiley:
I drove past it last night, and it is really fecking close, considering thats where it STOPPED i reckon there were allot of car drivers along the A30 had to change their underwear after it happened!
Well yesterday was a run around the Baggage System. I work for Delta as a Field Engineer working on the IT infrastructure and systems. Seen most of the major airports in Europe and yet never seen the cities themselves. :(What do you do at LHR?
the aircraft without a doubt stalled…she was feet away from the runway on 30 degree flaps with a high angle of attack, its what caused the stallis in question…
wind sheer, can completely remove every ounce of lift from the wings…normally it causes one wing to drop and the pilot has to act quickly to stop the thing from rolling or a wing hitting the ground, a jet taking off on another runway can cause the same effect. This is higly possible but the pilot did say he lost power not a sudden loss of lift.
If it was a bird strike, highly possible the engines would stutter,ie lose power momentarily…if it were a multiple strike this stuttter could have caused the loss of power and if it was both engines at nigh on full power this could have initiated the stall…and no matter how far you push the throttle engines these big engines take a long time to spool back up once power is lost…you all remember the airbus crash into the trees when the pilot tried to fly the plane without the computer…
If the plane ran out of fuel he would have know it well before hand, warning lights and all that…a fuel line blockage is possible but unlikely…depends upon where it was filled last…it could have been contaminated with water for instance…but all this is highly unlikely…
Multiple systems failure…possible would be interesting to know if the plane lost electrical power, the passengers could tell you that…the only vulcan bomber crash ever was caused by the failure of all four electric generators at the same time when it was on a test flight…no options but to jump…luckily they were high enough to all bail out…it can happen…complete failure in modern aircraft unheard of really but it is possible…technically and statistically.
Computer software failure is also a possibility but the 777 is well tried so again it seems unlikely…but again it is possible…
Think about pilot failure…what could he have done, engines running flaps down approach looking fine then it drops out of the sky…computers wont let him go so slow to stall…well not under most conditions…power failure is the key here…and what ever caused that will tell us the truth I think…and as guiliano said pilot error is likely to be in there somewhere…even if he did a great job once the failure occurred.
Flying planes is not difficult at all but understanding the software controls and options is…
Anyway thats my take on it…I could go on and on to be honest but not much use without more evidence
mystery solved…anyone informed the bbc? :stuck_out_tongue:
like many air crashes, its not usually one event, but a sequence that causes an accident.
Pilot apparently stated loosing all systems, passengers noted as saying the engines were spooling up like they would on take off, and eye witness reports the plane bowing up and down.
Sounds like systems failure somewhere, pilots pulled nose up to try and glide in, then probably stalled it, causing it to hit the deck
however, systems failure that cause both engines to loose complete power, so quickly?
even if this happened, he could have glided the rest, unless he lost hydrallic power as well, but all of this, instantanously?
It does sound like software on the on board computers, which is quite worrying that a software problem, can cause all of the aircraft systems to go awol
I still worry about Airbus- fly by wire! in olden days, if the aircraft suffered electrical faults, you could still (allbeit with diffculty) manually operate it
In fact people…
As far as i remember, the Boeing 777 is the first Boeing commercial aircraft to use fly by wire…
This is quite worrying, if there is a glitch in there somewhere, for the rest of the triple 777 worldwide fleet
Thanks for that information, person; most interesting.:smiley:
At least 11 Vulcans crashed killing over 40 crew - escapes of all crew were rare - I can’t identify the case you mention where there was an electrical faliure and all survived. There was a massive electrical failure in 1958 in the US which took out the electrical reserve, all died.
As for the 777 - there clearly was some electrical power or the passengers would have noticed and they clearly didn’t mention it.
There are lots of fuel indicators and warnings etc, but a plane running low on fuel could be caught out by a faulty fuel sensor - I have been stranded on Clapham Common Southside by that problem. If it is fuel, crew trying to run off the wrong tank (the reserve tap in the wrong position problem in bike terms) has been known to down aircraft before.
but its standerd practice to do a fuel check /route check/guage check every 15 mins…plus…when they set up for decent/approach,they have to adjust the weights and balances for landing including fuel…
this is an example of decent…anything fubar is gonna show up here i reckon…
smiled:D.
It has just been suggested on the 6 o’clock News that there may have been a faulty connection in the wiring between the auto-throttle controls and the engines.
Doubtless the truth will out in time.
think the guy did pretty well considering he had about 30sec to make all these decisons and bascially guide a falling boulder out of the sky avoiding the tube station, car park, a30, and not to mention a bp petrol station…
but makes you think if he had lost power 5min earlier when he would have pancaked onto the middle of london???
when i go back to work on tuesday i’ll see what kind of info i can pick up from the engineers.
Thats the most scary thing I have heard yet…engines shut off when they cant see a feed from the throttle control **** thats bad news.and has to be wrong…surely if the link is lost it would just maintain not stop…scary…on a bike with fly by wire yes shut down the engine but on a plane…sounds loopy…and bad design…Yes guiliano, forgot about a few of the mk 1 vulcans crashing with all on board…it has been a few years since I looked at the stats…it was difficult to get out of a crashing vulcan…pilots usually okay wsith their ejector seats, but the rest had to bail out…will have to check perhaps its the only vulcan to crash where they all got out…
stall is the loss of lift of the aircraft, well its wings actually…caused in this case it seems because it lost power to its engines so loosing forward momentum and therefore no laminar flow over the wings, or not enough flow to generate lift so causing it to stall…as I said its the cause of the loss of lift that is the mystery…why did the engines stop…
hmm I can see Boeing having to take the planes out of service if this turns out to be true to check what happened…
There is a list of Vulcan crashes on Wikipedia - As you say - the two pilots have ejector seats, the three to five other crew had to bail out old fashioned style. Even then it is not uncommon for crashes to kill the pilot and co-pilot even if they ejected. The other crew had a very poor survival rate.
BTW - on the Victor the pilot and co-pilot had ejectors, and the other three crew had explosive charges in their seats designed to throw them out of the seat and towards the hatch from which they had to bail out!
As for the 777 I can’t imagine there is a single throttle linkage so something other than dodgy electrics must be to blame here. If they already know what had failed and it was a simple duplicated component the world’s 777’s would already be grounded for a quick redundancy fix.
