Heated Grips
Well, I have some brand new heated grips to fit on the bandit but want to wire them in to the ignition switch so that I don’t leave them on accidentally.
Anybody know which wire is best to patch into and where it is, colour etc.?
Any tips?
Thanks.
Mark
Can’t answer your question but I have just had a set fitted to my Bandit 1250 by a guy called Steve Hallam - there is a thread about him in the praise/shame section.
Total cost for me was quite high (£100) BUT that included fitting Stebel horns, a very tricky job on my bike. I would say 80% of the cost was down to the horns.
It may be worth giving him a call. Steve does a fantastic job.
Too skint after buying the bike and bits for it so have to do it myself, enjoy learning how to do new things anyway.
Thanks for the contact though, it’s appreciated.
Heated grips are easy enough to fit, although mine come straight off the battery, they are the oxford ones though which have a feature that if left on the battery will only drain down to a certain level, is supposed to leave enough charge to be able to start the bike, never tested this though :stuck_out_tongue:
The Bandit seems to dislike anything other than a well charged battery so can’t afford to take it off the battery so need to wire them into the ignition.
I’m dead unlucky too so chances are some oik would come along and switch them on when I’m parked. :slight_smile:
I fitted mine from the battery but fitted a relay from the side light so they go off when the ignition goes off. If you pop into a motorfactors and ask for a 4 terminal relay (the 4 terminals are posative and negative for both grips and side light) It comes with instructions so you know which wire to put where.
It is pretty easy to fit and there is space behind the bandit headlight for the relay so a good place to take it from.
If you google the subject there are all sorts of guides with wiring diagrams and pictures that explain it better than I just did.
That sounds good, means I don’t have to lift the tank either. Might go for that one.
Cheers.
i think im gonna get a set fitted to the zed.:slight_smile:
absoultely right, fit a relay in the circuit and you can then use any wire that comes on with the ignition, ie a light wire to fire the relay to start up the grips, or at least allow them to be switched on…make sure the relay has enough current…ampage to handle the actual load of the heated grips…and that you use the right thickness wire throughout for the heated grips…otherwise you could have a fire…
Hopefully I won’t need to use much other wire other than what comes with the grips.
