im going to fit a fibre glass fairing seat ect to my k6 gsxr 600 how do you remove the original panels they seem to have some sort of plastic rivet type thing holding bits together can any one tell me how to remove them with out breaking them?
PM sent mate.
If they are anything like the ones on the R6 I might be able to help… do they have a little circular bit in the middle of the rivet? If so then get something sharp and push the bit in the middle in and the whole thing should just pop out.
Sorry if this doesn’t help.
Alex
youve probably worked it out by now???
Theyre pop-rivets. Push the centre out from the rear or sometimes they are secured by a half a turn. They are also generally pretty flimsy and tend to break! Make sure when putting them back in you pull the pin out of the assembly first. push the outside fastening through then push the securing pin through second.
easy peasy lemon squeezy!
Thanks did as said and it worked
thanks again now just gotta fit body work then take it all off to be sprayed ,
si
