Putting the gsxr back to standard so these are up for grabs. All parts are from a 06 gsxr k6 600 but will fit other bikes please check if they’ll fit yours.
Genuine pazzo shorty levers black with red adjusters only afew months old not a mark on them boxed with receipt £100 collected
Hel braided brake lines front race set up so two lines, one to each caliper with clear sleeving. Hel rear braided line in solid black with all the fittings £60
2004 R1 radial gold spot calipers with spacers to bolt straight onto a gsxr k6 k7 600 750 with brake pads which are below half worn. All the piston move freely but would do with a clean and lube up (the seals are fine as are the bleed nipples)
£100 for both
