I’m selling my 1000 as I want to race a 600 next year.
This is a very high spec race bike, and has been a race bike from new so not built from a crashed road bike. Has always been meticulously maintained.
Spec is as follows:
- GSXR 1000 K3 with full engine and frame numbers
- Full Akrapovic exhaust system (passes noise test easily at about 100dB)
- K&N Air Filter
- Ohlins rear shock set-up by KTEC
- KTEC front forks
- Power Commander 3 USB, mapped and producing 160BHP
- Dynojet quickshifter
- Promach Rearsets
- Harris Clipon handlebars
- Harris Clock/Fairing bracket
- 520 Race Chain/Sprockets
- Braided brake lines
- Crescent Quick Action Throttle
- Harris Exhaust mount bracket
- Beattie Guard
- Full fibreglass race fairing
- Ohlins steering damper
The bike had a major service earlier this year including valve clearances, spark plugs, oil & filter, coolant and brake fluid. Has had 4 hours use on track since. Everything is working as it should.
Spares include:
- Front wheel with discs, rear wheel without disc
- Sprocket carrier
- Front brake lever and clutch lever
- Standard screen
- Selection of sprockets for different circuits
Cosmetically it’s quite good, but does have the odd mark on the paint here and there. Only real damage is to one rear swingarm bobbin that has been re-welded so is still perfectly useable.
Mileage is showing 4890 miles, but has been on race gearing all it’s life so true mileage will be less.
Price is £2995 without spares or £3295 with the spares.
Call me on 07977 164279. Bike is located in Colchester, Essex.
