Ground Anchor
A bloke in Sheffield knocked this ground anchor up for me for 30 quid out of mild steel. Obviously you concrete it in up to the top plate (or even further if you want) then you can put a chain through the triangular hole at the top. A lot cheaper than whats out there, if anyone is interested in getting one let me know.
Seems a little expensive… I think a few people on here could do a better one than that.
If it had two beems that get cemented in it may be fairly good, but judging by the welding and the alignment it doesn’t look that great.
Idk, that’s my opinion… Maybe I’m just picky…
It looks nice. I love metalwork, thanks for sharing!
But… If I was a thief I would go straight for the mild steel anchor instead of the chain. Couple of clouts with a sledge hammer or a few minutes with a hacksaw
better idea is lifting shackle min 9.5t or bigger - You can buy one ebay cheap after service one
something like this - (is not mine)
http://www.ebay.co.uk/itm/Tested-Lifted-Galvanised-Shackle-8-1-2-TON-28mm-PIN-/150934850071?pt=UK_Lifting_Moving_Equipment&hash=item23246b0a17
Or the really cheap option, get some bent rebar from your local friendly concrete contractor. Bigger than 16mm to foil bolt croppers, maybe 25 or 32mm u-bars. You could even pair them up for added security since the material cost would be nothing.
Cast them into the ground with enough sticking out to get a chain under, lick of hammerite on the exposed bit and Bob’s yer uncle.
Wouldn’t look as nice as the welded solution of course. And that looks as solid as most of the stuff in the shops.
