Garmin Tire Pressure Sensor Monitor Installation
My latest YouTube effort.
Joby - just a small issue - in the UK it’s “tyre” :kiss:
PS - Why does the advert at the bottom of the video say “Russian Women Want You” ???
I’m multinational so maybe I can get away with it. I think the Ads are targeted at my typical audience. Please click on them so I’ll make loads of money.
it’s motorcycle, not modorcycle
Garmin Verb software ? :slight_smile:
From memory I think tyre pressure can fluctuate by as much as 20% depending on tyre temperature and outside temperatures, not entirely sure look it up if you want the definitive fluctuation.
If you inflate your tyres to 2 bar (29 psi, I Bar = 14.5 psi) when warm and set the low pressure warning to 1.8 bar (26 psi) and leave the vehicle out over night you will probably get a false alarm in the morning, 1.6 bar (23 psi) would probably eliminate the false alarms.
So the question folk will be asking is what low tyre pressure is too low? Well a couple of years back, I remember Mr & Mrs J riding the A1057 at a progressive pace two up with just 11 psi in the rear tyre :w00t: so on that basis 23 psi should not be too much of a problem. Blah, blah, blah disclaimer ride your bike with low tyre pressures at your own risk :Whistling:
Tyre pressure monitors are a good idea in that they should give you an early warning if there is a drop in tyre pressure, very handy if your unlucky enough to pick up a nail but they should not be relied upon on their own to do what it says on the box. There is no substitute for actually getting down and dirty and checking your tyre pressures in the proper job way.
Tyre manufacturers recommend tyre pressures be checked at least once a month and that it should be carried out first thing in the morning when the tyres are at their coldest and therefore lowest pressure.
I’ll try and look at that next. Do you want to see Verb Edit?
I am having trouble loading the verb edit software. It loads but as soon as I try to edit it comes up with an error. Have you used the verb yet ?
Yes it’s worked ok for me. What OS are you running? Windows 7? I’m using Windows 8 and it has been ok so far.
Windows 8 ? :slight_smile:
That’s weird. Maybe I can get a look remotely some evening.
That would be great or I could bring my laptop down the Ace sometime. :slight_smile:
