Was going to head out on the fazer this morning, got my kit on, started the engine choke on, everything ok. After the engine had warmed up I backed off the choke and fuel started to run out of the tootm of the engine. Upon further inspection it’s coming out of what looks like an overflow pipe from one of the carbs.
Any ideas what could be causing this? It was running fine 10 days ago with no signs of a leak.
I would be the last perston to ask really, but I believe I’ve read somewhere that if you don’t close off your fuel tap for the night, the fuel might leak in into the engine.
So after finally getting day where the heavens aren’t open and I’m not busy (sleeping) I finally got round to having a look at this.
Despite some gentle tappage with a screwdriver it’s still pissing fuel. So looks like a trip to the mechanic might be in order to get it sorted. Pain in the arse really as I’m skint
balls to that. drain the carbs, take them out and unscrew the float bowl covers, you’ll be able to see if they’re gunged up or something. it’s almost certainly a stuck float.
while you’re there, you might as well strip and clean them really.
