Front Sprocket/Chain noise
Is it normal for the chain to make a sound as it goes around the front sprocket or could it be that my rear wheel/chain needs re-aligning as it doesnt sound like the chains running straight? When I’ve got the bike up on the paddock stand and spin the back wheel it doesnt sound very smooth - should it be almost silent? Makes the same sound when im riding it aswell, coming to a stop - could be nothing but thought I’d make sure :slight_smile:
There is always some noise coming from the chain when you spin the rear wheel mate - bikes generate a lot of noise at e.g. 40mph from chain and tyres alone (with the engine switched off) you should only be worried if you can hear an obvious metal on metal scraping - e.g. the chain is rubbing the swing arm because the drive chain slider has worn out. Or clanking which indicates the chain is seriously out of adjustment and slack and banging on the swing arm/other components or because a sprocket is loose etc - but all these things are unusual (if you are on top of your maintenance) and not difficult to spot if they do occur.
If you are worried about noise coming from the front sprocket take the cover off and check the sprocket is on properly and the bolt is tightened/torqued up properly.
As for chain alignment - just make sure that the adjusters are set the same both sides of the axle.
If you want to get really anal about it you can purchase a ‘laser’ chain alignment tool:
http://www.probike.co.uk/it110009.htm
Cheers mate - no metal on metal noises, just ‘some’ noise, its never been quiet but has been slightly louder since I adjusted the chain at the weekend. It looks like its aligned ok to me on each side of the swingarm - only thing that made me really think about is that when I get over say 70-80 I get a kind of resonating vibration which seems to come from the chain but its all adjusted ok tho :slight_smile:
I’m sure it’s fine mate - just do all the usual checks and if it all looks good then I’m sure it’s ok. :slight_smile:
maybe try some chain lube?
Chains all clean and lubed up :slight_smile:
Always worth checking wheel alignment and the state of your chain/sprockets by trying to pull it off the back sprocket. If you can pull it so you can see daylight between the chain and the teeth, it’s worn.
Also check for tightspots on your chain and also see if the teeth on your front sprocket have become “hooked”
did you check the tension whilst sitting on the bike as the chian will tighten up when you get on
How do you do that then? You must have bloody long arms;):smiley:
That’s what I was thinking - but I thought it might be rude to ask! ;):P:D
HI
you are not trying to tension the chain when sitting on the bike just checking its not too tight. you then get off and readjust your chain if it is tight.
Does the usual 30mm ish free play not take this into account then?
On a triumph trident the recommended free play is between 35-45mm to allow for when the slack is taken up, when some one sits on the bike. Also with people weighing different amounts it is only a ball park guide, so a heavier rider would need more slack. By checking with the rider on the bike you do not put excess pressure on the wheel bearings, which could account for noise when riding and not when checking.
Also sounds to me like the chain is too tight. You’ll get a vibrating/grinding noise from the box if it is…sounds like it!
I also tighten the chain when weighted.
