Hi folks - I’ve fitted bungs myself to my Yam ace which was a piece of p1ss due to the fact that the bolt is accessible through a vent in the fairing (so no drilling/cutting involved) and there are two front engine bolts on each side - so no fear of the engine slipping in the frame when you pull the bolt out.I want to fit some bungs to the ZX7R - but I’m worried about taking the engine bolt out - as there is only one each side - e.g. when I take the right hand side bolt out to fit the crash bung slider is the engine going to slip in the frame? The R&G bung instructions say nothing about supporting the engine (e.g. sticking a jack and a block of wood under the exhaust collector box to prevent this happening).
Also when the bung is on - I’m going to have to unscrew it every time I want to take the fairing off - and seeing as it happens to be such an important bolt I really don’t fancy doing this + with the fairing in place there is no opportunity to support the front of the engine under the exhaust collector box with a jack.
Is the solution to cut a hole big enough for the entire crash bung to poke through the fairing - allowing me to remove the fairing without having to remove the bung.
Thanks for any advice! ;)
