VFR 750, got the moulded in indicators so they’re not removable.
Bought a new pair of wing mirrors, was only a couple of quid to get ones with build in indicators. can’t be a bad idea I thought.
the mirror ones are LED, now considering their minimal draw compared to the standard bulb unes, do you think I can wire them in directly without need for resisotrs and such?
Almost what he said, except “They should be fine in parallel”.
Certainly worth the “Suck it and see” trial.
They’ll work fine in parallel. The load that LEDs present to the flasher will be negligable compared to the load that the normal bulbs present … there will be therefore, virtually no difference in load, and the flasher relay should flash at it’s normal flash rate.
UPDATE: tested today and they do indeed flash with the same timing as before. Pity the mounting boots are rubbish though
