Engine oil
Need to get some engine oil… as this is the first time i do so… got some qstns :blush:
where should i get it from? (work @ farringdon)? :ermm:
what should i get (CBF600)?
should i wait for the engine oil light to turn on or do i top as when i deem necessary ?
thanks in adv
Get the oil that is recomended for your bike, its probably going to be Semi Synthetic 10/40. Most motorbike shops will sell it :w00t:
As for topping up, the oil should be changed periodically anyway, and I would hope that you would not have used any/hardly any oil in that time. If you have, yes, just top up. Do not overfill, it can cause as much damage as with it running low.
